Subpanel Disconnect Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 11:38 PM   #1
Subpanel disconnect question
I know that for a detached garage I need to have a disconnect for the power entry. The run from the main panel to the sub panel in the garage is about 50' or so. I'm going to run 2AWG alumn wire in 1 1/4" sch 80 PVC to the garage. I'm installing an 80 amp breaker for the subpanel (Possible future needs have 70 amps as a minimum out there. I've never seen 3AWG, so going with 2AWG I can run 90 amps, and I'm only using an 80 amp breaker to allow for any voltage drop effects)
That all being said, can I use a 100 amp main breaker panel as the disconnect? There is no issue with a larger breaker serving as the disconnect, since the entire feeder system is all protected by the 80 amp breaker?
rubber314chicke is offline   Reply With Quote
Old 06-09-2013, 12:52 AM   #2
Resi EC
Rewards Points: 252
80a breaker at the main panel, #2 awg guessing AL as feeders, underground to detached garage, then 100a MB panel.
Sounds good, couple things to remember
Need to run 4 counductors to the garage, so you can keep the ground and neutrals separate .. (2 feeds, 1 neutral, 1 ground)
At the detached garage, need to drive 2 ground rods, minimum 6' apart
You may have known all this but its worth mentioning
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
MTN REMODEL LLC (06-09-2013)
Old 06-09-2013, 12:58 AM   #3
Rewards Points: 1,016
Yup, 100a as disconnect is fine.
Don't suppose the garage has a ufer to use for the ground?
____________
Vince
Old 06-09-2013, 01:03 AM   #4
Resi EC
Rewards Points: 252
that would be nice ... lol
Installing central air question about conduit from disconnect to panel angelas111 Electrical 2 05-27-2011 07:37 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Subpanel question Scott2 Electrical 8 02-16-2010 06:32 AM
subpanel feeder question ssybert Electrical 4 01-28-2010 09:29 AM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
