05-05-2012, 03:29 PM
#1
Subpanel in Detached Workshop
Hello,
I'm new to this forum but people here seem to be very helpful. I have been trying to research running electrical to my detached garage but haven't found a scenario that matches mine.
I just bought a new house and want to move my workshop out to the detached garage. My workshop will contain a table saw, drill press, dust collector, planer and other misc. small tools but they are all 120v. Eventually I would like to put a window A/C unit out there for extremely humid/hot days and that may need to be 240v but I would like to stick with 120v. I will be the only one working out there so only 2-3 of pieces of equipment will be running at a time, for example I may be running the dust collector and table saw possibly the a/c unit if I ever get it.
The garage will require about 80 feet of wire from main panel in the house to the sub-panel and it will be run underground in conduit. I'm thinking I will need 6-3 wire to feed a 50 amp sub panel with grounding rod. I have heard the wire needs to be stripped in the conduit and then I've heard don't strip it.
So I guess the big questions are what type of wire do I need? Is a 50 amp sub panel going to be enough? Do I need to strip the wire in the conduit? I'm open to any thoughts/suggestions anyone has.
Thanks!!
05-05-2012, 03:35 PM
#2
Average Joe/ex-Navy IC3
We get this same question about once a week. Do a search through the forums, it has already been covered over and over.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
05-05-2012, 04:54 PM
#3
.....AND welcome to the forum. Plenty of knowledgable pros here willing to take the time to answer your questions (I'm just another DIYer, not one of them).
05-05-2012, 05:07 PM
#4
I=E/R
Originally Posted by tempest1785
Hello,
Thanks!!
You cannot strip NM-B cable and then pull it into conduit. Plan to use THWN wire.
05-05-2012, 05:19 PM
#5
Lic Electrical Inspector
Hello,
Thanks!!
Please update your profile with city/state and NEC version. It will make it easier for we professionals to assist you.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
05-05-2012, 08:13 PM
#6
Yeah, stick with conduit and THWN. And I would oversize the conduit just in case you find out that a 50 amp panel just isn't large enough. That way you can pull larger wires if the need arises. It is true that these type of installations have been reported here time and time and again, but if you want answers tailored to your questions you must ask them yourself....as you did. Have you done this type of electrical work before?
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-05-2012, 10:04 PM
#7
I have done a lot of electrical inside a house and even replaced a couple of main breaker panels but never ran a sub panel or anything outside.
05-05-2012, 10:39 PM
#8
One more question. Home Depot carries a 6 awg stranded wire with all 4 wires in a sleeve/casing whatever you want to call it. Can I run that in the conduit or do I need to buy each wire separately?
05-05-2012, 10:56 PM
#9
What you need will be 4 individual wires....3 6's and a number 8 for ground...and they need to be THWN, rated for damp locations. (underground conduit is considered a damp location no matter how well it is sealed)
05-05-2012, 10:59 PM
#10
if its NM cable, no good.
05-05-2012, 11:10 PM
#11
Licensed Electrician
Most THHN is dual rated THHN/THWN.
05-05-2012, 11:16 PM
#12
You are probably right....but I'm old school and remember when it was just THHN or TW.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
