Subpanel In Detached Garage In NJ Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 10:11 PM   #1
subpanel in detached garage in NJ help
I would like to install a subpanel in detached garage.
Going to run Small Welder (230 30 AMP),
Air compressor (115 20 amp), Power hand tools and lights.
I need to know wire size? Both CU and ALUM
I calculated #2 Alum. or #3 CU. 4 wires H H N G
1. 200 amp service in house.
2. Detached garage 200' away.
3. Installing in 100 Amp panel in garage.
4. Like to use Underground Copper feed to Panel.
Tedean is offline   Reply With Quote
Old 03-13-2011, 11:13 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
number 3 copper is correct. don't forget to keep neutrals and grounds seperate in your sub panel, and you will need a ground rod.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-13-2011, 11:46 PM   #3
Electrical Contractor
kbsparky's Avatar
#2 Aluminum is too small for a 100 Amp panel, you'll need a #1 for that.
IF you use copper, then #3 is fine. However, you only need a #8 copper grounding conductor for the 4th wire.
-KB
correcting existing subpanel in detached garage mtk Electrical 17 03-14-2010 02:49 PM
detached garage subpanel help edmart2 Electrical 7 03-19-2009 01:01 PM
Subpanel - detached garage without a floor SAS Electrical 12 03-05-2009 12:42 PM
Subpanel in detached garage gp_wa Electrical 6 10-07-2008 10:11 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 08:31 AM
