Subpanel In A Dedicated Closet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 12:17 PM   #1
Rewards Points: 1,062
Question
subpanel in a dedicated closet
i was wondering if a subpanel (which i plan to be a full panel in the future once i split into two meters) be located in a closet dedicated to it, and not exposed? it would be a very small closet with a 24" door and nothing else inside.
the reason i need to do it like this is because the main panel, from which i am diverting is in the basement directly under it and i will have to have unsightly JBs under the subpanel because most of the old cables won't reach the subpanel and i don't want to replace cables going on from the main panel onto the first receptacle.
having a closet allows me to enclose all this ugliness + the walls around the subpanel are plaster so i wouldn't really be able to even recess JBs so it would be REALLY UGLY
thanks
Old 08-07-2012, 04:01 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
thanks
You need to meet the correct working spaces in order for this to fly... read up on 110.26
I can tell you already, the 24" door might be an issue if this is a shallow closet.
Here, this will help you along...
The Following User Says Thank You to stickboy1375 For This Useful Post:
amakarevic (08-07-2012)
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
Removing existing closet gnomonklater Building & Construction 4 12-02-2011 12:14 AM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
Dedicated equipment space for subpanel? WoodworkerDave Electrical 11 09-14-2008 06:32 PM
Subpanel in closet?? jenlc75 Electrical 10 02-09-2007 01:57 PM
