Subpanel WITH Bonded Neutral - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 03:11 PM   #16
Rewards Points: 506
Don't know if it helps the discussion, but some folks like visual aids.
jlmran is offline   Reply With Quote
Old 01-24-2012, 05:32 PM   #17
Rewards Points: 506
And who has the authority to determine the location of the meter? The POCO (rural electric cooperative) or the homeowner?
Old 01-24-2012, 06:11 PM   #18
Rewards Points: 1,418
Originally Posted by jlmran View Post
What would be protected by a post-juxtasposition OCPD, which would not be protected by a mid-span or pre-juxtasposition OCPD?:
The building panel and electrical system.
Some kinds of failures in the conduit shared by the service wires and the "customer wires" can put the OCPD (below the meter) out of the picture.
As in:
Originally Posted by mpoulton View Post
... nothing can share a raceway with service entrance conductors. If you've ever seen them on fire, you'd understand why - that disconnect will do nothing!
Old 01-24-2012, 06:20 PM   #19
As in:
How is this interpreted? Is the DC required to be physically attached to the structure?
In this example, the DC on the pole is located quite literally the same distance as the panel attached to the structure, from the nearest entry/exit to the structure...if that is even a consideration.
Meaning, when one exits this structure, one can either walk one direction towards the pole (and DC) or walk another direction towards the panel. Both courses of travel are the same length.
(Whimsically) Let's imagine the situation compared to a main panel in one building and a subpanel in an outbuilding.
Here the pole with the meter is the main building and the main panel is the disconnect under the meter. An outbuilding, here, the house, needs a master disconnect for its electrical feed.
Old 01-24-2012, 08:04 PM   #20
Rewards Points: 506
So if I want the OVERHEAD service from the meter pole to the house to remain, my options are:
1. Have an additional conduit installed on the pole, to house the service conductors after the meter. This will separate the POCO lines from the customer's lines. This will require the installation of a "main disconnect" in the panel.
Or
2. Have the meter moved to the house, which also will require the installation of a "main disconnect" in the panel.
Are there any other viable options?
Old 01-24-2012, 08:25 PM   #21
MarginallyQualified
Rewards Points: 2,464
Damned few.
Keep the meter and manual disconnect in place...
From the load side of that disconnect run your new conduit up the pole to a new weather head over to the house where you install either a proper 3R service entrance with main breaker (more options i the future).
From that new gear, you can feed through to the NEW house panel (
which I assume also needs updating).
Old 01-24-2012, 08:39 PM   #22
" Euro " electrician
frenchelectrican's Avatar
The POCO will determed the meter location and homeowner don't have much say in there due the POCO have well written reguations so you will have to talk to the POCO about the meter location and will ask you for clearance if this is a pole topper ( farm system ) arrangement most farm I have deal from time to time they are dropping out for safety reason.
Merci,
Marc
Old 01-24-2012, 08:40 PM   #23
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you run from meter pole to house you will have to use 4 conductors make sure proper grounding at the meter pole and separate the ground and neutral in the house panel with a disconnect or new panel with main breaker. But it would probably be cheaper to install a new service on the house as long as it's not a mobile home.
rrolleston is offline   Reply With Quote
Old 01-24-2012, 10:11 PM   #24
Line feed to Subpanel is a white, black & bare ground wire
I need to replace the entire well pump electrical system as lightning fried everything. I replaced all the components and rewired everything up to the sub panel with a 10-2G with a maximum load of 28 amps. However, my problem is that the line feed coming into the subpanel is underground more than 200 feet away and the meter indicates 240 volts coming in. However I still need to try and add a 110 volt circuit to have a switch for a light and outlet for the sprinkler system to be plugged in. I think I have the wrong sub panel as it is the black plastic GE with 4 circuits as it does not look like I can adapt anything. I wired the outlet and light just like normal, the outlet indicates a open neutral and the light bulb blew. What the heck is wrong, am I missing something? PLEASE HELP!
furnray65 is offline   Reply With Quote
Old 01-24-2012, 10:15 PM   #25
First of all you should start a new thread on this one so it will not confuse the OP part.
Now you did open a new can of worm 200 feet with 10-2W/G with 28 amp load that is too much for that distance you should use #8 for this one second thing you do not have netural in there so that why the light bulb blew up quick due you have no 120 volts there.
And Jamias use the bare ground conductor for netural that is major no-no for this one.
Merci,
Marc
Old 01-24-2012, 10:17 PM   #26
Rewards Points: 506
Jamais means "never"?
Old 01-24-2012, 10:18 PM   #27
Oui ya got it.
Merci,
Marc
Old 01-24-2012, 10:24 PM   #28
Rewards Points: 3,256
Mystery word solved....thanks!
I thought he was telling me that only a guy named Jamais could pull my meter.
zappa is offline   Reply With Quote
Bonded Ground & Neutral in 240v subpanel RST Electrical 22 11-04-2011 02:18 PM
Bond subpanel Neutral directly to SE neutral using split bolt? Sierevello Electrical 1 01-30-2011 09:08 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
