Subpanel Beginner Questions - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 09:54 PM   #31
Rewards Points: 81
Originally Posted by Gac66610 View Post
You're right, 200.6 says #6 and smaller shall have a continuous white or gray outer finish, or by three continuous white stripes on other than green insulation along its entire length.
Should have looked it up.
I agree, I usually research this but I was in a bind with time after picking 36 straight 2x4 and you can guess how long that took when at your local Lowes
LarryM is offline   Reply With Quote
Old 12-21-2012, 11:11 PM   #32
I seriously doubt there are 36 straight 2x4's in our local Lowes & Home Depot together. Good luck.
Joe
Cornhusker Joe is offline   Reply With Quote
Old 12-22-2012, 04:09 PM   #33
Rewards Points: 81
Another silly question here
Does the order of the red and black matter on the 65AMP circuit in the main panel?
Old 12-22-2012, 04:11 PM   #34
Rewards Points: 81
Joe
haha...I counted all the 2x4s I put on the side and it was 78 bad ones to my 36 good ones.
I felt bad putting the 78 bad ones back because someone was going to end up with them unless they wanted to go through the 78 to find 1 good one
Old 12-22-2012, 04:26 PM   #35
Licensed electrician
Rewards Points: 1,010
The electrons do not know the insulation colors. It does not matter, the colors help to identify the function of the conductor.
Pool subpanel questions Simbilis Electrical 3 04-23-2011 07:44 PM
Subpanel Wire Questions mykayel Electrical 2 04-02-2011 02:35 AM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Help please - Upgrading subpanel! wtfh4xx Electrical 24 02-01-2010 06:55 PM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 03:19 PM
