Subpanel Beginner Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 07:00 AM   #16
Rewards Points: 1,548
Choice of:
1. Remove the black bar connecting the two ground/neutral bus bars. Use the bus bar without the screw or strap or jumper to the panel body for the neutrals. Use the bus bar with the screw, etc. to the panel body for the ground wires (equipment grounding conductors).
2. Leave the black bar in place and use both existing bus bars for neutrals. Remove the screw or strap etc. connecting either to the panel body. Install another bus bar (sold separately) directly on the panel back with good bare metal to bare metal contact for ground wires. This method would be used if you don't have enough holes in the bus for neutrals since each neutral must have its own hole and set screw. Two ground wires of the same size can share a hole but should not criss cross under the set screw (so one can't slip out, or get excessively nicked and fracture later).
The Following User Says Thank You to AllanJ For This Useful Post:
rjniles (12-14-2012)
Old 12-21-2012, 01:42 PM   #17
Rewards Points: 81
Ok I finshed the wiring within the sub panel. I didn't hook up to the main panel yet and plan to run metal conduit for 5" into the main panel above the sub panel...really is a sub panel
Tell me how it looks
Lowes didn't have white 6gauge THHN
LarryM is offline   Reply With Quote
Old 12-21-2012, 01:50 PM   #18
Licensed electrician
Rewards Points: 1,884
Well you are missing the conduit that the feeders should be run in. Also the green to the neutral bus is the wrong color.
Old 12-21-2012, 03:30 PM   #19
Rewards Points: 81
Am I going to fail inspection because of the green instead of white? Lowes didn't have the white so I figured green would suffice. Also I have to get the metal conduit still so I didn't hook up to the main panel
Anything else?
Old 12-21-2012, 04:33 PM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
Yes you will fail with a green neutral. And you need to get the conduit installed.
Coastal South Carolina
Old 12-21-2012, 04:45 PM   #21
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are these new circuits that require AFCI protection?
Old 12-21-2012, 04:52 PM   #22
Rewards Points: 81
I spoke to the electrical inspector regarding the AFCI circuits and he said these were fine...A sigh of relief on my part
Old 12-21-2012, 04:53 PM   #23
Rewards Points: 81
Jerks at Lowes, I should have known not to trust them...Guess I'll make a trip to HD tomorrow and get the correct wire.
Also I get the conduit from them since Lowes didn't have what I was looking for
Old 12-21-2012, 04:59 PM   #24
Resi EC
Rewards Points: 252
Other than what has been brought to your attention,
A very neat/clean panel
With the neutral, or lack of white, you could have run another black and used white electrical tape re-identify it as the neutral.
You can not use the white tape to re-identify the green to neutral.
Gac66610 is offline   Reply With Quote
Old 12-21-2012, 05:24 PM   #25
Rewards Points: 81
Thank you :-)
Curious, what are green wires for? I have never seen it before
Old 12-21-2012, 05:27 PM   #26
k_buz's Avatar
GFI is not the same thing as AFCI.
Old 12-21-2012, 05:37 PM   #27
Rewards Points: 81
Sorry that is what I meant... Crazy expensive for those circuits so I was glad to save about $250
Old 12-21-2012, 06:21 PM   #28
Engineer
Rewards Points: 161
Thank you :-)
Ground
diystephen is offline   Reply With Quote
Old 12-21-2012, 06:26 PM   #29
The conductor would need to be a #4 or larger before it can be re-identified.
Gac66610 (12-21-2012)
Old 12-21-2012, 08:29 PM   #30
Resi EC
Rewards Points: 252
You're right, 200.6 says #6 and smaller shall have a continuous white or gray outer finish, or by three continuous white stripes on other than green insulation along its entire length.
Should have looked it up.
Pool subpanel questions Simbilis Electrical 3 04-23-2011 06:44 PM
Subpanel Wire Questions mykayel Electrical 2 04-02-2011 01:35 AM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Help please - Upgrading subpanel! wtfh4xx Electrical 24 02-01-2010 05:55 PM
Subpanel installation in outbuilding fls Electrical 19 03-16-2008 02:19 PM
