Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 07:18 AM   #1
electrician / handyman
subpanel
does a subpanel in a house need separate ground rods
sethc is offline   Reply With Quote
Old 02-18-2008, 07:21 AM   #2
Doesn't your tag line say you're an electrician?
jerryh3 is offline   Reply With Quote
Old 02-18-2008, 07:24 AM   #3
I need a quick answer I am in the code book now i have been a commercial electrician for 14 years and in commercial work all subpanels need a separate steel ground not sure about residential SA
Old 02-18-2008, 07:51 AM   #4
Licensed Pro
If the subpanel is inside the same structure as the main panel, it does not need a separate ground rod, but it does need to be fed by four wires (H,H,N,G). It does not have to have its own disconnect.
If the subpanel is in a separate structure, it must have a grounding electrode (rod), its own disconnect, and preferably be fed by four wires.
Old 02-18-2008, 07:55 AM   #5
thanks for the answer house helper
Old 02-18-2008, 07:57 AM   #6
What is the rule with disconnects? If the sub panel only has six breakers, is a disconnect still required at the outbuilding?
Old 02-18-2008, 09:44 PM   #7
Rewards Points: 2,350
No, but only if it isn't considered a lighting and appliance branch circuit panel.
InPhase277
Old 02-18-2008, 10:27 PM   #8
Electrician
InPhase277
Which is going away in the 2008 edition...
chris75 is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
subpanel question Brik Electrical 2 11-30-2008 05:31 AM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 12:58 PM
