subpanel
does a subpanel in a house need separate ground rods
Doesn't your tag line say you're an electrician?
I need a quick answer I am in the code book now i have been a commercial electrician for 14 years and in commercial work all subpanels need a separate steel ground not sure about residential SA
If the subpanel is in a separate structure, it must have a grounding electrode (rod), its own disconnect, and preferably be fed by four wires. |
thanks for the answer house helper
InPhase277 |
Which is going away in the 2008 edition... :) |
| All times are GMT -4. The time now is 04:36 PM. |
