Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 08:32 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by cyras21 View Post
My neighbors cousin is an apprentice and he had a load meter or something that measured the draw (i think that's what he called it) at the box.
Each circuit was drawing 18A - 19A.
They don't cost me too much. The lights are only on from 5pm to 10pm, but there is an obvious increase in my consumption for the month.
At 80 amps, at 5 hours for a month would add over 120 bucks to your electric bill...
Old 08-18-2012, 08:37 PM   #17
What's not legal, the boxes?
If so, how would I make it legal or is an actual subpanel a better idea?
cyras21 is offline   Reply With Quote
Old 08-18-2012, 08:39 PM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
A permitted sub panel, permanently installed and inspected.
Old 08-18-2012, 08:43 PM   #19
uh... I'm paying a lil more then that I think. I'm on the budget plan meaning I pay the average of the year previously and I'm paying around $200 a month.
Old 08-18-2012, 08:53 PM   #20
E2 Electrician
I do the same, i was just saying what it would cost, not saying you weren't... its very possible you are.
Old 08-18-2012, 11:39 PM   #21
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The box is basically a subpanel but not permanent. It contains individual circuits for each receptacle.
These are the type of boxes I was looking at.
http://www.dxsoundco.com/#Lighting_Controllers
Whoa!! I can't even begin to list the safety hazards with this.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-20-2012, 04:42 PM   #22
I'm sorry but I'm pretty ignorant when it comes to electrical work.
Would one of you mind explaining what is wrong with using one of these boxes as a temp subpanel?
Old 08-20-2012, 04:44 PM   #23
E2 Electrician
Flexible cord supplying a subpanel, 120 volt receptacles fed via 240volts... Who knows what other violations they did under the cover....
Old 08-20-2012, 05:26 PM   #24
Master Electrician
I've seen similar boxes to this used many times but there's never breakers in them. Usually they're standalone units that have internal fuses for the different receptacles. The unit itself will have an amperage rating so it's more like a piece of equipment than a service box. Of course they also have the right receptacles installed too
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-20-2012, 05:32 PM   #25
E2 Electrician
I'm curious how many appliances get toasted with the 240v supply on the 120v receptacles? Lol...
Old 08-20-2012, 06:00 PM   #26
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You see similiar, though code compliant, distribution panels in stage and sound lighting. At a boxing match I saw a 200 amp square d load center that was converted to cam lock to supply temporary lighting hung above the ring. They had the thing mounted on a 2 wheel dolly.....
Old 08-20-2012, 06:03 PM   #27
Here's what I was imagining, may or may not be different from the above box.
A 220 outlet installed with a breaker between it and the main line with the box plugged into the outlet. The box would contain breakers for each receptacle.
Is it that cord, from the box to the outlet that isn't safe? Is there another way to "hook" this up to be temporary that is safer?
The only reason I'm looking for it to be temporary is because there is a chance of moving in the next year or so. I guess I could always install the subpanel and convey my christmas decorations.
Old 08-20-2012, 06:34 PM   #28
This is kind of what I was thinking...
Old 08-20-2012, 08:05 PM   #29
electures's Avatar
The two on the right look like Light-a-Rama. I know for a fact they use 30a feeds.
Old 08-20-2012, 08:32 PM   #30
E2 Electrician
All this stuff you find online is bull**** and non- code compliant...
Subpanel Grounding buchman Electrical 7 06-24-2012 12:44 PM
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 01:38 PM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
