Submeter With CTs - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 09:18 PM   #1
submeter with CTs
I am researching submeters. And I see the submeters with CTs. All the diagrams show the meter being connected at the panel. If i get a submeter with the clamping CTs I can place it anywhere on the lines? my whole feed runs through conduit and i believe there are a few open spots on the conduit. I know there shouldnt be open spots on the conduit. but there are. I prefer not to mess with the panel box if i can avoid it. Theres lots of big scary wires in there.... This is for my own personal use to monitor a single circuit.
Thanks,
Mike
And any recommendations on submeters are welcome...
miket3 is offline   Reply With Quote
Old 07-22-2010, 09:23 PM   #2
Licensed electrician
Rewards Points: 1,496
There are plug-in meters to do what you want. IIRC Black and Decker had one. I am sure there are others.
http://blackanddecker.com/Energy/def....mc_id=BD00041
Old 07-22-2010, 10:01 PM   #3
Thanks but....
There arent any plugins for me.... My circuit (i think) is single phase 3-wire 240volts. I thought i wanted a plug-in but that would force it to be outside. And I dont want that option. Thats why i am looking at the power meters with CTs. And there arent any 240volt plugins that I could find, other than a 230v marine plugin.
Old 07-23-2010, 10:46 AM   #4
If you know the wire gauge you can measure the voltage drop across 10' or 20' of it and read the current to reasonable accuracy. You're using the wire as a shunt.
20' of #10 copper gives 0.02 ohm and so would have 200 mVac across it with 10 A through it. In this case your scaling factor would be 20 mV/amp or 50 A/volt.
The voltage sensing leads can be very small gauge.
The voltage sensing terminals need to be separate from the terminals that pass current.
http://en.wikipedia.org/wiki/Four-terminal_sensing
Or you could get a commercially made shunt.
http://en.wikipedia.org/wiki/Shunt_(electrical)
Electrical SubMeter Wiring Help - Please. Jasondt2001 Electrical 50 01-07-2009 02:35 PM
Issues with a submeter? theatretch85 Electrical 9 12-27-2008 01:00 PM
Submeter anthony1159 Electrical 7 12-13-2008 03:39 AM
