Submeter - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2008, 09:11 AM   #1
Submeter
Hi, I have a question, I ran a sub panel into my dadís garage, using 6/3, I did isolate the ground bus from the neutral bus in the sub. I put a 60 amp breaker in the main panel and a 50 amp main in the sub panel (this way Iím hoping if it trips I wonít have to run to the basement). My question is, I want to put a sub meter to monitor the power usage in the garage, Iíll be using it as a small shop and want to pay for the electric I use. I went to the local electric supply store and they want $500 for a sub meter, they told me I can put in a metersocket and a meter for under $200. So if I put the meter socket in line with the 6/3 before the sub panel (I assume itís just like a service entrance would be) will it work properly? Thanks, Anthony
anthony1159 is offline   Reply With Quote
Old 12-11-2008, 09:24 AM   #2
Rewards Points: 886
I think someone in an earlier thread said that you can get watthour meters on Ebay for cheap.
I'm not qualified to tell you how to install the meter, so I'll leave that to a real electrician!
Ultrarunner2017 is offline   Reply With Quote
Old 12-11-2008, 12:30 PM   #3
DIYer
Also this was suggested:
http://www.theenergydetective.com/st...s/ted1000.html
A full outdoors meter box is probably overkill. Look at this TED or a landlord submeter rated for indoor use.
Gigs is offline   Reply With Quote
Old 12-11-2008, 02:15 PM   #4
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I second that, this is the same product I would have suggested.
Jamie
jamiedolan is offline   Reply With Quote
Old 12-11-2008, 06:32 PM   #5
DIY
Rewards Points: 150
That would be me.
http://shop.ebay.com/items/?_nkw=uti...r20w&_osacat=0
Definitely the most cost effective way to go IMO, but of course you cannot do any automatic data logging.
gp_wa is offline   Reply With Quote
Old 12-11-2008, 11:15 PM   #6
Rewards Points: 506
Send a message via AIM to theatretch85
I can personally say as a current user of this product that I would highly recommend it for your situation! It can be installed on either end of the main cable feeding the garage space and does not need a computer to be connected to just calculate the total power consumed in a month. It allows you to enter the utility rates and it shows you real time cost and estimates the current months projected kWh usage and total cost. The computer allows you to do real-time data logging, this only works if the computer is connected and on all the time. If you have any questions about the TED Energy Detective just ask, I'd be more than happy to provide you with any additional information on it.
theatretch85 is offline   Reply With Quote
Old 12-12-2008, 07:03 PM   #7
Thanks Guys, I think this is exactly what I need at a decent price. Anthony
Old 12-13-2008, 03:39 AM   #8
DIYer
Heh, that TED manufacture should start giving us a commission at this rate. :P
