Submersible Well Pump Powered By Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 04:00 AM   #1
Submersible well pump powered by generator
Can I run a 230v submersible well pump 3 wire to a generator and do I need a pressure tank it's used for irrigation purposes
Miss1955smb is offline   Reply With Quote
Old 07-28-2012, 05:56 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Yes, if the generator is sized to carry the load.
Yes, or your pump will build and lose pressure very quickly and cause your pressure switch to cut on and off rapidly. (click, click,click,click)
wirenut1110 is offline   Reply With Quote
Old 07-28-2012, 08:07 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Isnt the pressure tank only required for instant access to water and to stop the pump from running every time a draw is required, saving start ups on the motor and increasing its life of the pump?
Old 07-28-2012, 10:24 AM   #4
Rewards Points: 510
If he uses a relief valve, shouldn't need a pressure tank but, if he uses a pressure switch the pump would just short cycle. Same as it would if the bladder in the pressure tank for whatever reason, loses air.
If the discharge side can handle the output flow of the pump and can't build pressure, it should be ok.
I'm thinking of a residential irrigation system, where the heads on the open zones may not allow enough flow to keep the pump from building too much pressure.
Hope this makes sense.
Old 07-28-2012, 10:40 AM   #5
E2 Electrician
I got it, plus i missed the connection of using a pressure switch without a pressure tank...
Generator - for sump pump fjacky Electrical 5 03-10-2012 11:32 AM
Submersible water pump question Ronnie1a Electrical 6 12-19-2011 12:09 AM
submersible pump problems sparky1967 Plumbing 12 06-21-2011 05:32 PM
Submersible pump plumbing cwalt43 Plumbing 0 09-15-2010 12:25 PM
