Submersible Well Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 05:30 PM   #1
Submersible well pump
Hi I'm pretty handy around the house (Have to be), now my well pump (franklin electric submersible 3 wire 230 volt) has quit. I have the motor control open, the fuses are good the pressure switch is powered. Now there are 5 contacts across the control box and I do not know what voltage I should see across each. My ohm meter was built in the USA ARMACO and is analog. I prefer to check the motor by voltage readings.
I am getting 150V between contacts 1 and two no other voltage
jiminny is offline   Reply With Quote
Old 07-22-2012, 05:32 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If you look at the back of the control box cover, there should be a label that will tell you the correct ohm readings you should be getting to help you troubleshoot this.
Old 07-22-2012, 05:40 PM   #3
" Euro " electrician
frenchelectrican's Avatar
First of all Stickboy have right answer and also let me add this along the way KILL or remove the power source before you do anything on FE pump controls.
And do you know what size pump motour it is ? due I have three differnt diagram to use so that will affect the whole thing due they are not the same.
Merci,
Marc
Old 07-23-2012, 04:34 PM   #4
submersible pump
Hi Marc, It is a 1/2 hp 230 volt 3 wire. Since I posted, I went to my sons place for a shower, came back, tried the faucet and low and behold!! water. Beautiful wet water. Obviously my well was dry, we are in a prolonged drought here as is everyone, will have to conserve until we get rain. Thanks for the warning and the response, Cheers.... Jim
Old 07-23-2012, 04:36 PM   #5
E2 Electrician
You may want to invest in a pump tech to prevent your pump from running dry.
The Following User Says Thank You to stickboy1375 For This Useful Post:
frenchelectrican (07-24-2012)
Old 07-24-2012, 12:21 AM   #6
The other option which I do install from time to time is low pressure cut off switch so when the water pressure get too low it will shut the pump off they act little differnt than a conventail pressure switch as you are used to it there is a addtional spring or diagram which it will trip if under 20 PSIG IIRC.
To get it back on line you will have to manually hold the cut off switch until you get over 20 PSIG or whatever the cut off pressure point is then it will run like normal pump.
Not all place will sell the pressure switch avce low pressure cutoff feature in there. ( well compaines will have this useally in stock and some plumming supply will have this as well )
On my well I did have low pressure cutoff switch but it is set for 18-22 PSIG range so if the water level get too low or the well screen ( at the bottom of the well ) get clogged that will shut the pump off before it will destory the pump.
It did actually happend few time when the LPCO ( low pressure cut out ) tripped when the screen clogged and replace it and it did slove the issue.
Merci,
Marc
Old 07-24-2012, 12:24 AM   #7
E2 Electrician
Interesing...
Old 07-24-2012, 12:30 AM   #8
Interesing...
Oui c'est.,,
Voila pour le link .,
http://store.thepumpwarehouse.com/pr...-Switch/Detail
Ici le side photo of what it look like.,
Merci,
Marc
Old 07-24-2012, 07:52 AM   #9
Submersible Pump
Thanks again, I installed the Auto version last time my pump acted up.(actually there were to small leaks in the waterline and a defective external check valve which did burn out the pressure switch.) Probably saved my pump this time. I will make sure it is set on auto. Merci Boucoup, Mon Amie!
Submersible pump wiring? Master Brian Electrical 15 05-08-2012 11:20 AM
Submersible well pump pressure tank? kyle79 Plumbing 2 04-10-2012 04:44 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
submersible well pump . first start. ryanh Plumbing 11 07-12-2010 09:26 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
