Sub-panels - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 05:11 PM   #1
sub-panels
Hello, I'm new to this thread and need help.
I am putting a 200 amp box in my house with a 100 amp sub-panel and a
60 amp sub-panel. I get confused on the wire I need for which panel.
Will someone direct me as to what to purchase as:
from meter to 200 amp panel=
from 200 amp panel to 100 amp panel=
from 200 amp panel to 60 amp panel=Thanks in advance.
Dave
Daviedav is offline   Reply With Quote
Old 03-05-2012, 05:16 PM   #2
Licensed electrician
Rewards Points: 1,876
Will you be using cables or a conduit method?
Old 03-05-2012, 05:51 PM   #3
Sub panels
Thanks Jim,
I will be using cable.
Neutral path between two main panels EMiller Electrical 13 03-17-2014 07:48 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 08:43 AM
Metal roof over Zip panels Arky217 Building & Construction 1 08-14-2011 10:37 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
