Old 11-23-2012, 02:20 PM   #1
sub-panel wiring needs
Hi!
I would like to have a 50A 240/120 sub-panel in my basement. There is a less than 40 feet run 2-conductor and ground wire cable there with the following print on it 6-6-8 Type SE cable Type XHHW CDRS 300V to ground E11134M (UL). Also, the ground wire that goes to my main panel is running very close by.
Question: for a sub-panel, can I run the 2 hot wires from my main panel on this cable and use the ground for return, or very much against NEC? The ground needs to be separate for a sub-panel, but as I said, running close by already.
Thanks for your help!
Mike
mikeclueless is offline   Reply With Quote
Old 11-23-2012, 03:21 PM   #2
Field Service
Mike
No, you cannot use a ground as the return. You will need 3 conductor wire for 2 hots and a neutral. It will also contain a ground wire. The neutral and ground will also need to be unbonded in the sub panel.
diystephen is offline   Reply With Quote
Old 11-23-2012, 03:26 PM   #3
JuzRick's Avatar
Mike: for a 50 amp subpanel you need at least #6, 4 conductor to properly feed the service as needed. So your looking at: a 50 amp dbl pole breaker coming from the main service equipment to the subpanel line side. Two hot conductors on each line side.. then your neutral on the neutral side terminal, and the ground on its ground terminal side(if not shared..depending on the panel setup). I hope I read comprehended you, answered your question correctly!
JuzRick is offline   Reply With Quote
help wiring a panel ex-28 Electrical 17 01-27-2012 03:51 PM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 09:17 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 10:50 AM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 12:28 PM
