Sub Panel Wiring & Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 08:45 AM   #1
Sub panel wiring & grounding
I plan on putting a sub panel in a detached building about 100 ft away from main panel. I know the neutral & grd busses are seperate in subpanel. Do I need a grd rod at the detached building and do I have to run a grd wire from main panel to sub panel?
kwcamaro is offline   Reply With Quote
Old 03-06-2010, 08:58 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Yes and Yes. Follow this
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
kwcamaro (03-06-2010)
Wiring from panel Rick N. Electrical 6 07-10-2013 05:25 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
grounding for sub panel aarons600rr Electrical 3 04-17-2007 09:04 PM
