Old 09-17-2012, 07:21 PM   #1
sub panel wire size
Built a new pole barn and want to run 100amp service to it. I will be tapping off a 200amp main panel going straight into the ground with pvc and running about 350ft to the garage. what wire choices would a electrician use and what size conduit.
hardgear69 is offline   Reply With Quote
Old 09-17-2012, 07:23 PM   #2
E2 Electrician
stickboy1375's Avatar
sub panel wire size
I would take advantage of 230.40 Exception no.4 and run out of the meter to the pole barn if feasible... depending on where the existing meter was located in relation to the pole barn.
Old 09-17-2012, 07:27 PM   #3
sub panel wire size
Can't do that because of where the meter is located.
Old 09-17-2012, 07:37 PM   #4
E2 Electrician
sub panel wire size
Too bad, would have saved you some money... so whats the load at the pole barn, be nice to factor in some type of voltage drop.
Old 09-17-2012, 08:37 PM   #5
sub panel wire size
Not completly sure 2-220 outlets, about 10-110 outlets, maybe 8 8' florescent lights other than that no real plans
Old 09-19-2012, 01:15 PM   #6
sub panel wire size
run 2 1/2 conduit 4/0 4/0 2/0 and an equipment ground #1 al would work fine just did this here in oregon a run of 230 ft. for a 150 amp panel , your going 100 more ft. a ...long run so u need to have your wire up sized . if you was close a triplex #2 would be fine . cost for 4/0 like 800.00 0r more bucks . but worth it . do it once right
shockme123 is offline   Reply With Quote
Single Phase Panel from Three phase 3 Wire Delta bsps Electrical 9 06-02-2012 09:44 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 11:49 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
What size wire for 100 amp sub panel Bean Electrical 7 01-24-2010 08:31 PM
