Sub Panel Wire Gauge Size - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 01:07 PM   #1
Rewards Points: 31
sub panel wire gauge size
i recently had my electrical service upgraded and due to a continued lack of breaker positions i plan on using my old smaller breaker box as a subpanel. i will use a 40 or 50 amp 2 pole breaker in the new box to feed the subpanel. what gauge wire do you think i should use from the new breaker to feed the subpanel, maybe 6/3? i will maybe have 5 or 6 romexes coming into the subpanel for now.
pberm1962 is offline   Reply With Quote
Old 10-02-2011, 01:15 PM   #2
Rewards Points: 150
6/3 is the correct size
Sunny B. is offline   Reply With Quote
Old 10-02-2011, 01:26 PM   #3
Rewards Points: 31
thank you
thank you , i will use 6/3
Old 10-02-2011, 02:36 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
8/3 for 40 amp, 6/3 for 50 amp
Coastal South Carolina
Old 10-02-2011, 02:53 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
Originally Posted by rjniles View Post
6/3 for 50 amp
...or 60A.
Old 10-02-2011, 04:16 PM   #6
Code05's Avatar
Rewards Points: 1,104
Originally Posted by Speedy Petey View Post
...or 60A.
You gonna clarify why this may be legal? Else some DIyer is gonna think 6/3 NM is good for 60 amps.
Code05 is offline   Reply With Quote
Old 10-02-2011, 04:39 PM   #7
A "Handy Husband"
rjniles's Avatar
I think he means that #6 is rated for 55 amps and since this is a feeder you can up size to the next standard breaker size (60 amps). As long as the calculated load is not over 55 amps. Personally I like to stay with a 50 amp breaker for #6
The Following User Says Thank You to rjniles For This Useful Post:
Code05 (10-02-2011)
Old 10-02-2011, 05:36 PM   #8
As long as the calculated load is not over 50 amps.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Code05 (10-02-2011)
Old 10-02-2011, 07:40 PM   #9
A "Handy Husband"
rjniles's Avatar
I meant that but my finger slipped thanks for the correction.
Old 10-02-2011, 07:48 PM   #10
Missouri Bound's Avatar
Hate to spoil this party....but whatever guage you wind up with....you will still need a 4th wire for a ground for the sub-panel. And the ground must be bonded to the sub-panel, and the neutral isolated.....just saying.....
Old 10-02-2011, 10:02 PM   #11
Code05's Avatar
Thank you, that is why I posted my earlier response.
Old 10-02-2011, 10:08 PM   #12
Code05's Avatar
Modern 6/3 NM has a #10 ground. 4 wires total.
The Following User Says Thank You to Code05 For This Useful Post:
Jim Port (10-03-2011)
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
mixed gauge wire on 15 amp circuit GretaDIY Electrical 4 07-03-2010 03:20 PM
Size wire for A/C, A/H and Range? tripflex Electrical 6 06-07-2010 10:38 AM
What size wire for 100 amp sub panel Bean Electrical 7 01-24-2010 07:31 PM
