sub panel using dryer wire
I would suggest not cutting the cable, so that someone else could re-install the end as a dryer cable. Or if you later found out you needed a bigger subpanel and needed to string a fatter cable, you could put the 30 amp cable back as a dryer cable.
In turn this may require some funny routing of the cable to use up slack.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
