Sub-Panel Upgrade - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 09:06 AM   #1
Sub-Panel Upgrade
Hello, I am curious for some guidance in upgrading a sub panel in my house. Currently the meter is on the front of the house, with a shut off switch on the meter. The panel is inside the building. Is it a high enough level of safety to just shut off the switch at the front of the house so that I can remove the old panel and put a new one in?
Jerrys84 is offline   Reply With Quote
Old 08-14-2012, 09:38 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Pretty much, but check power before proceeding.
Old 08-14-2012, 09:44 AM   #3
Yes, you should be fine.
As above said, check power to make sure.
Also, is there any possible way someone could come by and hit the switch and you don't know about it? thus turning on the power while you are working on the panel?
if so, then is there a way to lock the switch in the off position or put a sign on the switch?
Crazy stuff happens all the time, you have to look out for yourself.
parman is offline   Reply With Quote
Old 08-14-2012, 01:07 PM   #4
Yes, there is a cheap cover over the switch, i could afix some sort of lock to it to prevent someone from absentmindedly throwing the switch. Thank you for the info.
Old 08-14-2012, 01:37 PM   #5
I dont wanna inundate everyone with small electrical questions, so im posting to the same thread, but is it alright if i have two ground wires going into the same bar slot? I ran out and wasnt sure if i should pigtail em', assume its fine cause its the ground, or do something else. Any info would be appreciagted, thanks.
Old 08-14-2012, 05:31 PM   #6
jbfan's Avatar
Rewards Points: 224
Most brands of panels allow 2 grounds under the same screw.
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Main Panel Upgrade Invisible-Man Electrical 21 08-23-2011 04:24 AM
Upgrade panel, add subpanel, add tandem breakers? oregondiy Electrical 11 12-30-2010 11:45 PM
Breaker panel upgrade Jim Patton Electrical 2 11-04-2010 09:47 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 08:35 PM
