-   -   Sub-Panel Upgrade (http://www.diychatroom.com/f18/sub-panel-upgrade-153644/)
Jerrys84 08-14-2012 08:06 AM
Sub-Panel Upgrade
Hello, I am curious for some guidance in upgrading a sub panel in my house. Currently the meter is on the front of the house, with a shut off switch on the meter. The panel is inside the building. Is it a high enough level of safety to just shut off the switch at the front of the house so that I can remove the old panel and put a new one in?
jbfan 08-14-2012 08:38 AM
Pretty much, but check power before proceeding.
parman 08-14-2012 08:44 AM
Yes, you should be fine.
As above said, check power to make sure.
Also, is there any possible way someone could come by and hit the switch and you don't know about it? thus turning on the power while you are working on the panel?
if so, then is there a way to lock the switch in the off position or put a sign on the switch?
Crazy stuff happens all the time, you have to look out for yourself.
Jerrys84 08-14-2012 12:07 PM
Yes, there is a cheap cover over the switch, i could afix some sort of lock to it to prevent someone from absentmindedly throwing the switch. Thank you for the info.
Jerrys84 08-14-2012 12:37 PM
I dont wanna inundate everyone with small electrical questions, so im posting to the same thread, but is it alright if i have two ground wires going into the same bar slot? I ran out and wasnt sure if i should pigtail em', assume its fine cause its the ground, or do something else. Any info would be appreciagted, thanks.
jbfan 08-14-2012 04:31 PM
Most brands of panels allow 2 grounds under the same screw.
