Sub Panel To A Sub Panel? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 08:56 PM   #16
Originally Posted by Rob1975 View Post
You should have sufficient service. Even if every spot is taken on your panel, most homes use less than 40amps. I would not sub off of a sub. The wiring gets too complicated. Your best bet is to pull from the main panel. If there are no spaces, move a few circuits to the first sub panel and then use the open spaces to supply the second sub panel. IMO this would be the best solution. Load calculators can be found on the net. I don't have enough posts to insert a link, so just google online electrical load calculator.
Good Luck!
OK thanks. Im pretty sure I have plenty of service. Just no room to pull from the main.
zikarro is offline   Reply With Quote
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
