Sub Panel Recommendation - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 08:48 PM   #1
Sub panel recommendation
I'm finishing my basement and determined that I need a subpanel because I only have 3 slots left in my 200a main panel and I have 7-8 more circuits to install to complete the basement.
Those 7-8 circuits are:
2 - 20a circuits for wetbar recepts (GFI) and home theater
5 or 6 - 15a circuits (AFCI) for recepts and lighting for office, and other rooms
I plan to use two of the remaining slots in the main panel for the breaker that will feed the subpanel, but I'd like to know recommendations on what size subpanel (60 amp or larger?), and what size corresponding breaker to feed the subpanel? I have some extra 8-3 and 6-3 wire leftover from another project, and the subpanel will be able to be located right beside the main panel in the basement panel room.
Also, if possible given everything mentioned above, I'd like to have 2-3 slots left over for any future expansion just in case.
Let me know if I'm leaving any necessary info out.
Thanks!!
Straightgrain is offline   Reply With Quote
Old 03-27-2009, 09:35 PM   #2
I'd put a 100a panel in
Then you can feed it with #6 & use a 60a breaker ($17 maybe)
If you need heavy duty power then feed it with 100a breaker (53?)
Old 03-27-2009, 09:45 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Like scuba said, put in a 100 amp main lug panel, feed it with a 60 amp breaker and use the 6/3.
Make sure to get a ground bar for the sub and seperate the ground and neutral wires.
Old 03-28-2009, 07:13 AM   #4
Got it....thanks guys!
Old 03-28-2009, 12:46 PM   #5
Rewards Points: 58
Search "sub panels" on this forum for further information if needed. There many, many threads on this topic.
Old 03-28-2009, 12:46 PM   #6
If you need heavy duty power then feed it with 100a breaker ($53?)
Just to be clear
You need to use different wire if you are going to feed it with 100a
The #6 is good for the 60a 240v
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
