Sub Panel Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 09:49 AM   #1
Question
Sub panel questions
I'm installing a sub panel in my garage off of my 100 amp service. My city requires you to abide by the NEC 2002. I pulled 1 1/4" schedule 40 30" deep with rigid vertically. The run is about 15' with 4-#4s. I have a 12 slot Siemens panel that can be main lug or main breaker that I'm going to use as my sub. Going to put a dual pull 60A as my feed to the sub.off of my service.
Do I need grounding rods? Or is my #4 to the service ok by itself?
Is the Siemens panel I have ok to use?
I have read if you have more than 6 spaces you can't use a main lug. Is this correct? And if so should I put ground rods.
Intended breakers
20a-compressor. 20a-oulets. 15a-fridge. 15a-outlets. 15a-lights. 15a-ext. Lights + landscaping
Last edited by dimyself121; 08-15-2011 at 10:54 AM. Reason: post #6 explains about garage being attached or detached
dimyself121 is offline   Reply With Quote
Old 08-15-2011, 10:02 AM   #2
Rewards Points: 6,652
There is plenty of info on here about what you are going to be doing. Do they plan on updating to a more newer NEC anytime soon? Check out what your local requires regarding the ground rod out at the structure, due to they are in a older NEC. Here is some info to help you out More Clarification on Detached Garage Sub-Panel The picture that Stubbie posted in that one, if I recall follows the 2008 NEC.
Old 08-15-2011, 10:07 AM   #3
Master Electrician
Rewards Points: 3,698
A seperate structure requires a main disconnect(main breaker in the panel).
brric is online now   Reply With Quote
Old 08-15-2011, 10:26 AM   #4
Just call me Andrew
Rewards Points: 1,020
He never said whether or not his garage is detached.
Andrew
secutanudu is offline   Reply With Quote
Old 08-15-2011, 10:29 AM   #5
If he is pulling a sub out there, unless he uses emt, he will have to treat it as the rules state, regarding the sub. You are correct though, he did not state that it was detached, so everyone is going to assume the rules regarding detached structures.
Old 08-15-2011, 10:42 AM   #6
I believe it is considered attached. The garage was built detached 6ft. Away from the house, 5yrs after the house was built but now they are connected with a permanent mud room
Old 08-15-2011, 10:44 AM   #7
Would you consider it attached or detached?
Old 08-15-2011, 10:46 AM   #8
Master Electrician
Sure. I'll bet his main panel is in the garage and that the garage has a dirt floor.
Old 08-15-2011, 10:56 AM   #9
Do you know if the mudroom changes were done with permits? In relation to the garage, where does the main from the POCO come into the house, along with location of the current main panel?
Old 08-15-2011, 10:59 AM   #10
No! I have a 24x30 garage......cement floor with a 100amp service in my utility room which is about 15 ft away. Which now are connected by a mud room which also has a cement floor along with walls and a roof. Unfortunately no dirt
Old 08-15-2011, 11:05 AM   #11
Yes the main is about 15' away in the utility room. I came out the house rigid for the vertical pieces and ran schedule 40 for the underground horizontal portion .. I believe they pulled permits but I'm unsure. Just bought house 9 months ago
Old 08-15-2011, 11:16 AM   #12
Master Electrician
I stand corrected. After further explanation IMO that is an attached garage. No need for ground rods with a four wire feeder.
The Following 2 Users Say Thank You to brric For This Useful Post:
dimyself121 (08-15-2011), gregzoll (08-15-2011)
Old 08-15-2011, 11:23 AM   #13
See brcc, that is why I like you. Your answers are straightforward and do not skirt the question, nor get too far in depth that you need to read between the lines in what you are trying to tell the other person.
Old 08-15-2011, 11:53 AM   #14
So is the panel I asked about in my original post ok to use as a sub
Old 08-15-2011, 12:19 PM   #15
Yes, since you are wanting to have disconnects close to where you are working at. That is the main purpose of a sub-panel, besides extending a main panel for more spaces, so that you do not have to pay to install a larger panel. Just make sure that your existing 100 amp service, is going to be able to handle the extra load that you are going to be placing on it. What electric appliances do you have in the home already? Do you have electric heat, electric stove, electric dryer, electric water heater, heat pump?
You are also welcome to post a picture of your existing main panel if you wish, for further input on this update from those that can let you know, so you have enough info to file the permits if needed with your local.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
More Sub Panel Questions rdkng07 Electrical 6 05-25-2011 09:46 AM
New Breaker Panel Questions AvalonGirl Electrical 10 06-02-2010 11:20 AM
Service panel and general questions reddman Electrical 3 05-12-2009 12:54 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
