Sub Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 03:38 PM   #1
Sub panel question
Hello everyone!!
I need to install a new sub panel, my main panel is 150 amps, what is the largest sub panel i can put in? Can i put a 100 or 125 amp panel in? Any help would be great thanks!!!
Dogger is offline   Reply With Quote
Old 09-28-2011, 04:48 PM   #2
Licensed electrician
Rewards Points: 1,622
You could put in a 200 amp rated panel. It would be limited by the breaker size that feeds it.
You need to perform a demand load calculation to see if your service can support the new loads.
Question about sub panel lilryry Electrical 12 07-29-2011 11:32 AM
Electric panel enclosure question globus999 Electrical 6 11-23-2010 09:30 PM
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
