Old 07-28-2007, 06:14 PM   #1
Sub-panel question
Deleted by poster.
stealth71 is offline   Reply With Quote
Old 07-28-2007, 06:54 PM   #2
Agent 000
SecretSquirrel's Avatar
Sub-panel question
The 12 gauge wire is rated for 20 amps, but that is figured with a safety margin, assuming that the full load would only be 15 amps at any given time. The most that you could do with a subpanel and your existing wire is have 2 - 10 amp breakers in it. That doesn't really provide for much, does it? You mentioned future needs which would require even more ampacity than you presently have. For the long haul it would probably be best to "bite the bullet" and get the appropriate sized feeder to the garage.
See this thread for some related information on feeder sizes and overcurrent protection.
SecretSquirrel is offline   Reply With Quote
Old 07-28-2007, 07:13 PM   #3
Sub-panel question
That's the conclusion I am coming to as well. Thanks for the reply.
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
