Sub-Panel Q.s - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 01:02 PM   #1
Sub-Panel Q.s
I am looking to have a sub-panel installed, but have a few questions since I will do the wiring to the panel but have a licensed electrician do the final hook up from panel to panel. First off, the county I live in uses NEC 2008. So in light of this, rather than run 4 wires to the main, is it permitted to run the 3 wires and set up a grounding rod(s) outside. This is an attached garage
angrysmileyface is offline   Reply With Quote
Old 07-22-2009, 01:50 PM   #2
No. You need 4 wires but no ground rod.
jerryh3 is offline   Reply With Quote
Old 07-22-2009, 01:52 PM   #3
Licensed Pro
Under the 2008 NEC, it's 4 wires detached or attached. The only difference is a detached structure needs its own grounding electrode, an attached structure does not.
Old 07-22-2009, 02:17 PM   #4
Alrighty then. Guess that means I will be adding a length of conduit with a 4th conductor to my plans. Electrician I talked with said it could be done with 3-wires and ground rod.
Old 07-22-2009, 02:38 PM   #5
Fire this guy before he starts. He doesn't know what's he talking about. He did know this was an attached garage, right?
Old 07-22-2009, 03:05 PM   #6
He knew, but yet I am not sure if he is using an older version of the code. Good part is nothing is in place permanently. Can SEU be run in conduit without derating it?
Old 07-22-2009, 04:10 PM   #7
SEU or SER? Why would you use cable in conduit?
Old 07-22-2009, 05:40 PM   #8
Rewards Points: 2,350
Doesn't matter what version of the code he is using, even going back to the 60s maybe. A 4-wire feeder has always been required for an attached structure.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
