Sub Panel Near Bathtub - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 09:04 PM   #1
I wanted to use the space above a bathtub for putting in an on-demand electrical water heater and some a sub panel and other electrical connections.
With 10 foot ceilings I have about 40 inches to work with. My plan is to separate
the water heater and pipes from all electrical connections into a separate water tight compartment and to further isolate the electrical area from the bathtub area by spray foaming the walls and "floor" of the compartment with watertite and putting on a sealed access door.
Any suggestions to help me are most welcome and can I do this within code?
argentum13 is offline   Reply With Quote
Old 05-01-2010, 09:13 PM   #2
Master Electrician
Rewards Points: 3,678
Electrical panels are not allowed in bathrooms in the USA.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
argentum13 (05-01-2010)
Old 05-01-2010, 09:22 PM   #3
As stated it does not meet code
Locate the sub in another room, basement or anywhere else
Also not allowed in a clothes closet
Min clearaces needed
Old 05-01-2010, 11:08 PM   #4
Electrician
Rewards Points: 760
Are you serious you want to know if it is alright to put a panel above a bath tub.
I know everyone says there is no such thing as a dumb question but this may very well be one of the first.
darren is offline   Reply With Quote
Old 05-02-2010, 12:58 AM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Just make sure it's easily accessible if you are sitting in the bath tub. If by chance the breaker for the lights trips you don't want to have to get out or stand up in the bath tub all wet, in the dark, in order to locate the breaker. That would be a falling hazard.
Old 05-02-2010, 08:07 AM   #6
Master Electrician
Originally Posted by red squirrel View Post
just make sure it's easily accessible if you are sitting in the bath tub. If by chance the breaker for the lights trips you don't want to have to get out or stand up in the bath tub all wet, in the dark, in order to locate the breaker. That would be a falling hazard.
lmao.
Old 05-02-2010, 08:33 AM   #7
Just call me Andrew
Rewards Points: 1,020
He asked...and will now (probably) not do it. So he did the right thing by asking.
Andrew
secutanudu is offline   Reply With Quote
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
