Sub Panel Metal Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2008, 07:16 AM   #1
sub panel metal studs
I want to install a sub panel in my garage, my house has metal wall studs. Is there any concern with installing the sub panel between two studs?
donaldbyrd is offline   Reply With Quote
Old 01-25-2008, 07:35 AM   #2
Licensed electrician
Rewards Points: 1,884
You may want to add some wood studs to provide a more secure anchoring surface.
Electrically there would be no problem.
Old 01-25-2008, 09:30 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Flush mounted or surface?
Old 01-25-2008, 04:18 PM   #4
Rewards Points: 6,652
Usually wood 1x4 are screwed to the stud, and 2x4 are used as firestops and to keep the metal studs from flexing.
Old 01-25-2008, 04:50 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
If your wanting to put the panel in the wall between the living space of the house and the garage your going to be in trouble meeting firestop codes. Don't put it there.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 08:23 AM
metal studs to build up attic floor Airborne180 Carpentry 6 12-13-2006 04:02 PM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 04:31 PM
