Sub Panel For Me ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 10:18 AM   #16
Rewards Points: 240
yeah, 20 amp for my 5 amp fridge . is that just in case i decide to run 4 fridges ?
Fix'n it is offline   Reply With Quote
Old 06-29-2013, 10:22 AM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
Well....it could be 15a....but the real reason is so that if something else on that ckt trips the breaker that the fridge is also on....and your not home.....your beer does not get warm......
Old 06-29-2013, 10:36 AM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
The fridge can be on a 15A ONLY if it is a dedicated circuit.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Fix'n it (06-30-2013), Kyle_in_rure (06-29-2013)
Old 06-29-2013, 12:12 PM   #19
MarginallyQualified
Rewards Points: 2,464
I could have sworn there was a thread on that awhile back and everyone was saying they had to be seperate..............
The owners manuals (ie lawyers) almost all call call for a dedicated circuit for each... but the amp load involved almost never needs more than a single 15A; a single 20A is a healthy safety margin against future need.
What about the fridge... plus the gas stove ignitor only?
Old 06-30-2013, 08:19 AM   #20
Rewards Points: 240
it is 5a, says on the fridge.
valid point.
i don't care about future needs. if someone else wants to run a bakery out of here, they can run their own wires.
i am thinking = stove, range hood, under cab lights and counter outlets on 1 circuit. there will be only 6 counter outlets. 15a. bad idea ?
Old 06-30-2013, 08:24 AM   #21
Rewards Points: 240
now, back to the original question.
seeing as how i have enough 14g wire to run from the main to this room. would this be better, or run 1 large wires to a sub panel ?
i am going to be running 14/2 (or 12/2 if i 'have" to)in the rooms.
Old 06-30-2013, 09:01 AM   #22
MarginallyQualified
seeing as how i have enough 14g wire to run...
Again, with the exception of the lighting and a dedicated refr circuit... EVERYTHING else (120V) will be on 20A circuits using 12ga wire. Using a sub panel doesn't change this.
If the main panel has the space and the wire can pulled without too much bother... those 30 foot homerun's (wire run from panel to first device box) aren't going to cost more than the homerun's from the sub-panel + the sub-panel + the heavier wire needed to feed the sub-panel.
hth
Old 06-30-2013, 09:05 AM   #23
valid point.
Are you pulling a permit and having it inspected? If so that won't pass.
hacksawjiw is offline   Reply With Quote
Old 06-30-2013, 09:07 AM   #24
Rewards Points: 240
ok. what is the smallest roll of 12g wire can be bought ? do i need different colors ? or can i just use white, then mark the ends ?
and what size conduit should i use to this room ?
Old 06-30-2013, 10:20 AM   #25
MarginallyQualified
In Chicago and using EMT conduit...
12ga wire comes in 500 foot rolls.
You'll need a minimum of two colors (black and white).
I'd start with a wiring plan that has the first box of each circuit
(the homerun/feed) as close to each other as possible and then pull the several feeds to this one (or maybe two) starting point and then branch out from there.
The rest is about "fill" (how many wires per 1/2 or 3/4 emt) and of course laying out and installing all those boxes and conduit.
(it won't be any fun at all)
Old 07-04-2013, 09:17 PM   #26
Rewards Points: 240
i only need to run conduit if it is exposed = basement. so i would run conduit in the basement, to a below the kitchen box. then a conduit up through the bottom plate to a large box behind (but accessible) a cabinet. then run romex out of that.
i have 12 open slots on my main.
Old 07-04-2013, 09:24 PM   #27
Rewards Points: 240
now that i think about it. i think i would like a subpanel = easier for my wife to get to.
what size wire, conduit, panel, breakers, etc, do you recommend ?
i think i can buy larger wire by the foot ?
Old 07-06-2013, 08:30 AM   #28
Rewards Points: 240
i bought 250' of 12/2 . i will use as much of this as i can.
i will have to figure out the rest myself.
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
