Sub Panel For Me ? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 08:57 AM   #1
Rewards Points: 236
sub panel for me ?
i am building a completely new kitchen. because of the amount of new circuits i need, should i use a sub panel, instead of running all the circuits from the main ?
code says i need 6 new circuits. this seems accessive to me, as i am running just 1 right now. for all but a dishwasher. anyway....
Fix'n it is offline   Reply With Quote
Old 06-29-2013, 09:08 AM   #2
Rewards Points: 236
oh. i do have plenty of 14awg wire that i could use if i ran seperate circuits from the main. but i don't want to run more than 1 conduit in the basement. i do have enough empty slots in the main box. would 14awg be large enough for a kitchen ? (gas stove)
Old 06-29-2013, 09:18 AM   #3
MarginallyQualified
Rewards Points: 2,464
a) you should already have X circuits in the kitchen (3-5);
b) you shouldn't need to add very many more; so....
1) How many new circuits EXACTLY?
2) Is there room in the main panel for them?
3) How far is the kitchen from the main panel?
Some basic reading: LINK
Old 06-29-2013, 09:29 AM   #4
Rewards Points: 236
a) old house = is what it is.
b) ALL of the old stuff(nearly all N&T) is being replaced.
1) code says about 6. i think 3-4 would be fine.
2) yes
3) 30'ish
Old 06-29-2013, 09:34 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
14 can not be used for the sabc.
jbfan is online now   Reply With Quote
Old 06-29-2013, 09:42 AM   #6
Rewards Points: 236
Originally Posted by jbfan View Post
sabc.
what is that ?
Old 06-29-2013, 09:51 AM   #7
jbfan's Avatar
Rewards Points: 530
The counter top receptacles, dining room, pantries.
Old 06-29-2013, 09:52 AM   #8
what is that ?
Smal appliance branch circuit. Basically it's the two circuits required for your countertop receptacles. They must be 20 amp circuits so you will need number 12
hacksawjiw is offline   Reply With Quote
The Following User Says Thank You to hacksawjiw For This Useful Post:
jbfan (06-29-2013)
Old 06-29-2013, 10:03 AM   #9
Rewards Points: 236
2 20 amp circuits for the counter tops ?
i'm not going to be doing any welding in there
Old 06-29-2013, 10:05 AM   #10
Rewards Points: 236
gosh darn it. i have all this 14g, and i can't even use it
Old 06-29-2013, 10:10 AM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Ok....to the best of my old feeble knowledge...here is what you have to have.....
2 dedicated 20A ckts for counter top...both have to be GFCI. You can have as many outlets tied to those 2 20a ckts....but you still have to have at least 2.
1 20A for the dishwasher.
1 20A for the disposal.
1 20A for the Fridge
If you have a built in microwave....it has to have it's own 20A ckt
You can use that 14g for lights.
I was just looking at a post someone put up regarding the 2014 NEC......big thing....AFIC's basically everywhere. I guess someone needs to come up with a load center that is just one big AFCI with feeder breakers.
Old 06-29-2013, 10:12 AM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Me feels you are woefully ill-informed about how things electric work. Especially if you think two 20A counter top circuits is excessive or "welding worthy".
I would strongly suggest a couple of good books on home wiring BEFORE you begin this project. Otherwise I can see some costly mistakes in your future.
Old 06-29-2013, 10:14 AM   #13
Dw and disp can share a 20A circuit. If separate each CAN almost certainly be served with 15A.
If dedicated can be 15A.
Most kitchen circuits DO NOT need AFCI protection. Lighting does though.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (06-29-2013), mm11 (06-29-2013)
Old 06-29-2013, 10:15 AM   #14
Oh, and a sub-panel close to the kitchen would be a good idea.
Old 06-29-2013, 10:17 AM   #15
JOATMON
ddawg16's Avatar
I could have sworn there was a thread on that awhile back and everyone was saying they had to be seperate..............
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 03:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
