Sub Panel Or Main Panel Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 08:58 AM   #1
sub panel or main panel grounding
have a utility pole approximately 25ft from the house, with a utility service meter and service disconnect box below the meter. The service entrance wire is 100amp and enters the house at a connection at the attic floor level and then runs 12ft through the attic and 5ft down the wall to a new 100amp service panel. There is a grounding wire on the outside of the house (where the service enters the house) The ground wire is connected to the service entrance ground wire and runs down the side of the house to a grounding bar next to the foundation. Because of the service disconnect box on the outside would the service panel in the house be a sub-panel or a main panel? And the proper grounding for that sub or main panel in the house would be?
dghowery is offline   Reply With Quote
Old 10-13-2010, 09:18 AM   #2
Licensed electrician
Rewards Points: 1,478
Anything other than the first means to disconnect the power is wired as a subpanel with the grounds and neutrals isolated. Check out these diagrams to better understand.
http://www.dropshots.com/stubbie4#al...0Installations
Main grounding electrode wire to panel rovers1973 Electrical 4 03-18-2010 06:18 PM
Proper grounding of meter main to breaker panel tns1 Electrical 3 09-08-2009 09:24 AM
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 01:44 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
