Sub Panel Load And Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 05:52 PM   #1
Sub panel load and advice
Hey there, I've stalking these forums for a bit and love the great advice!
I am planning on finishing my basement here and was hoping to get some input on my plans for adding a sub panel in the basement. This is all based on advice I've seen here, if I got it right!
I'll need to run it about 20' from main panel in garage, into basement via rim joist. Planning in schedule 80 PVC conduit.
The basement panel will have...
Full kitchen (dishwasher, fridge, electric range, microwave, etc)
Washer dryer
Separate home theater equipment circuit
Theater room
Play room
Bedroom
Kitchen / dining room
The bathroom, sump and fire alarms are already on the existing panel.
I was looking at a 60 amp main lug for the sub panel with 6# wire from main, but now I'm wondering if I should go 100amp with 4# and have plenty of capacity.
I want to do it right and my town actually doesn't require permits or inspection as the permit included this as living space when he house was built a couple years ago.
Any thoughts or advice are appreciated!
TimMauriello is offline   Reply With Quote
Old 10-11-2011, 06:00 PM   #2
Electrical Contractor
kbsparky's Avatar
60 Amp might be pushing it a bit with all that kitchen and laundry room stuff. All electric??
If you decide to go with a #4 feeder cable (copper), you are limited to 85 Amps, since this is not an entire service feeding a single dwelling.
If you want a full 100 Amp capacity, you'll need at least #3 copper wires for the hots, but you can reduce the neutral to a #4, with a #8 ground.
Will there be a water heater, or any HVAC connected to this sub-panel?
-KB
Old 10-11-2011, 06:19 PM   #3
I would much rather go with extra capacity and do it right here the first time, so I'll definitely change plans to 100 amp and the #3 wire.
Yeah, it's all electric appliances, but no additional water heater or hvac needed.
Structural Advice for Removing Load bearing Wall? sdba Building & Construction 1 05-11-2017 02:16 PM
Want to open up a load bearing wall - I need advice on a header to carry the load graysqwrl Building & Construction 4 07-16-2011 08:16 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Load Bearing (point Load) Wall Removal Advice Stringer9 Building & Construction 5 11-09-2010 10:14 AM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
