Sub Panel And Layout - Electrical - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 12:09 AM   #1
Rewards Points: 83
Sub panel and layout
Hello all, I will get right to the point to try and not make this to long. I am finishing the basement and my main is full. After reading on this site untill my eyes were bleeding I decided to install a sub panel. I have a double 30 open in the main after removing a wall oven from upstairs. There was only 10\3 going to that oven so after reading here I believe that I need to go to a double 50 in the main and use 6\3 wire to go to the sub. I have done a lot of research on this even though my explanation skills are not proving it right now! I have drawn a picture to try and explain it better but I have even confused myself after getting done and looking at it so I am not sure it is going to help. I am installing a upflush sysyem, a base board heater and a mini bar fridge which I understand need to be on their own breakers.
I have also read quite a few contradictions that lights and outlets need to be on their own, seperate circuit so that has added some confusion. Also the way i took it that 14/2 was good for lights but outlets should be done with 12\2. Sorry if this is confusing but I am just in the planning phase of this. If you would just look this over and bash away!! Any and all comments and suggestions will be appreciated! Sorry about the pic also, i did it in a hurry and it was my first attempt
Thanx
rodsteryz is offline   Reply With Quote
Old 12-09-2009, 12:13 AM   #2
Rewards Points: 83
I forgot to add I have purchased a square D 125 A with 12 slot box and after looking at the pic it gets pretty cluttered in the bathroom. I would like to have 2 lights and 2 GFCI outlets on each side of the sink.
Old 12-09-2009, 12:26 AM   #3
You must run a 20 amp circuit for the bath recep(s).
You can run the bath lights/ex fan off this circuit but I wouldn't.
I'd also run a 20 for the heater and a 20 for the upflush.
General lights and receps can be 15A.
Receps at the bar must be GFCI.
Don't forget to switch the bar lights
220/221 is offline   Reply With Quote
Old 12-09-2009, 12:35 AM   #4
Electrical wholesale Dist
First question I have is... you have a main panel (with a KWH meter on it) right??? And you have a sub panel right??? And now you want to add another sub panel for your basement???
KWH = kilowatt watt hour meter
ELECTWHOLESALER is offline   Reply With Quote
Old 12-09-2009, 12:52 AM   #5
Rewards Points: 83
Man, you guys are quick to respond!! Thanx. Sorry I didn't explain very well. The main panel is full and I just want to install on sub panel, there is not already a sub. Yes it is metered. I had down 20 for the heater and the upflush but I do think I will do some rethinking and do all receps and lights on their own. A couple of the overhead bayh lights and the ex fan are already installed and they are on a different circuit. Like I said the drawing is pretty horrible but I was just trying to get out the general idea, going from that do you think about going 50a and using 6\3? I would rather over do it for future additions than have problems later. I guess my question is should I go more than 50A?
Old 12-09-2009, 08:55 AM   #6
So what you have is a meter-main combo...and it is full except for the 2-pole30 you removed? What I'm getting at is that you don't want to overload the main panel, most older homes (pre mid 90's) had the basic 100 amp panel, now a lot of contractors are installing 200 to 400 amp, so there will be no over loading issues later...
Old 12-09-2009, 09:19 AM   #7
What size is your main panel...100a 200a ?
I have 200a Main with a 100a sub 3' to the left
I just added another 100a sub in our new addition
Old 12-11-2009, 08:31 PM   #8
Pro
no 6/3 to sub panel, you need a 4 conductor. 2 hot, 1 neutral, 1 ground.
pruane is offline   Reply With Quote
Old 12-11-2009, 10:13 PM   #9
subpanel
yes it would be 6/3/ w ground
adamselec is offline   Reply With Quote
Old 12-11-2009, 10:51 PM   #10
Most call me Sparky
6/3 has 4 conductors
Rod,
how many amps is your existing service and is there any way you can list what breakers is currently in panel. because it is possible you may need to upgrade your service...Thnx
Chasm is offline   Reply With Quote
Old 12-12-2009, 10:32 AM   #11
Electrician
Rewards Points: 760
Doing a load calculation is not a bad idea, you can find them online.
I will be suprised if you need to upgrade your service, your not adding much of the load for the service.
Do you have natural gas or electric for HWT and furnace, if it is natural gas you will be fine with a 100A service. If you have electric heat you probably already have a 200A service so you will be good to go.
darren is offline   Reply With Quote
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Breaker Panel Layout mfleming Electrical 27 01-09-2009 05:42 PM
Panel Layout jamiedolan Electrical 11 11-18-2008 02:47 PM
Wire layout within panels WoodworkerDave Electrical 9 11-17-2008 10:09 PM
Need Help With Circut Layout ChrisSovari Electrical 4 03-17-2008 09:33 PM
