Old 07-12-2011, 10:51 AM   #1
Sub panel instead of generator transfer switch
I can easily use the "kit" transfers switch from lowes, but was thinking I could save a few $$ and use a sub panel instead. I just wanted to get some feedback from people who have done this. I only need a 5 or 6 circuit sub panel, feed it from the main and have a double 30amp breaker that will connect to the generator feed. I know the safety questions is how to ensure backfeeding will not occur, so the homeowner will need to be sure to turn off the breaker coming from the main. Thoughts?
vtboy51 is offline   Reply With Quote
Old 07-12-2011, 11:28 AM   #2
Mad Scientist
To avoid the possibility of killing anyone by backfeeding the service, you would need an interlock kit that physically prevents the sub panel's main breaker and generator connection breaker from being closed at the same time.
McSteve is offline   Reply With Quote
Old 07-12-2011, 11:58 AM   #3
Square D makes an approved interlock equipped sub panel.
The blue box store has it for less than $100. Square D QO48M60DSGP
AandPDan is offline   Reply With Quote
Old 07-12-2011, 01:06 PM   #4
The transfer or interlock mechanism is still mandatory and can be part of the main panel (post #2) or part of the subpanel (post #3) or a transfer switch (similar to a pre-main panel transfer switch) in between.
The advantage of not putting a transfer switch before the main panel is that it would be a suitable do it yourself job not requiring calling the power company to disconnect and then reconnect the power.
One style of transfer switching subpanel does not require moving cables from the main panel to the subpanel. Instead individual 12 and 14 gauge wires for perhaps six to ten chosen branch circuits run through a conduit to the main panel and connect to the respective circuit wires and breakers. The generator feed connects directly to the subpanel. Reliance makes some of these.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 07-12-2011, 01:58 PM   #5
I=E/R
a7ecorsair's Avatar
Are you the homeowner?
a7ecorsair is offline   Reply With Quote
Old 07-12-2011, 04:02 PM   #6
Missouri Bound's Avatar
The best and most cost effective method is using a panel such as Allanj mentioned. It is available at the big box stores and available in 6 to 12 circuit configurations. Each Circuit "switch" is itself a transfer switch, so the "homeowner" doesn't have to think or remember anything except flipping the breaker to it's alternate position. Being sure to flip off the main doesn't cut it.....a transfer switch or interlock is a MANDATORY requirement, as Allanj has already mentioned. These pre-manufactured panels take care of all those issues.
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 01:17 PM
