Old 03-29-2011, 12:18 PM   #1
Sub Panel Installation
Building an addition to my house, master BR, bath, laundry. Plans call for a 100A subpanel, exterior mounted. 9 circuits.
-can the panel be mounted after the stucco is installed, as long as the mounting screws are long enough to penetrate the OSB sheathing?
-can all 9 circuit cables enter the back of the panel through the same 2" knockout? it's the only knockout on the back of the panel, and i'd rather not have 5-10 penetrations through the side of the house, if i can have one that's hidden by the panel itself. i'm not sure if there's a clamp that would hold all of the cables in that 2" knockout though.
-i bought a 6 space, 12 circuit panel. planned on using slimline breakers, but maybe a panel with more spaces would have been more appropriate...
thanks guys.
ironnickwhite is offline   Reply With Quote
Old 03-29-2011, 12:25 PM   #2
Are you sure they mean exterior, as in outside?
That's not common, a watertight panel is rather expensive, and could be prone to moisture problems.
Maybe they meant surface mounted?
You mentioned you bought a panel, it would need to be weatherproof.
A six circuit is too small, you don't want to plan ahead with slim-line breakers and no room for expansion.
Also you will need arc-fault breakers, which may not be available in slim-line.
Do It Right is offline   Reply With Quote
Old 03-29-2011, 12:34 PM   #3
Master Electrician
3R panels are not overly expensive. Yes, unless you have an inspector that objects, use a short PVC nipple through the wall to accomodate your cables.
brric is offline   Reply With Quote
Old 03-29-2011, 12:53 PM   #4
the panel i bought was a outdoor/rainproof Square D enclosure. tried to keep it as small as possible, but definitely need more spaces, room for expansion, good call.
and definitely need AFCI breakers, didn't realize they don't come slimline. thanks a bunch.
Old 03-30-2011, 06:36 AM   #5
IronNick,
Why does the panel need to be outside?
Old 03-30-2011, 10:33 AM   #6
Originally Posted by Do It Right
IronNick,
I suppose it doesn't have to be. Plans call for it to be outside. Feeder cable from main panel would hit new addition at the bathroom. If I put the panel at same point just inside instead of outside it would be either above toilet or above vanity. I'm guessing that's why plans were drawn the way they are.
Old 03-30-2011, 11:18 AM   #7
Electric panels mounted on the exterior are common here in Southern Califorina.
Old 03-30-2011, 11:43 AM   #8
Licensed Pro
An electrical panel cannot be in a bathroom, so it would either have to go outside or in another room (hallway, laundry, or bedroom, if you can meet the clearance requirements).
HouseHelper is online now   Reply With Quote
Old 03-30-2011, 12:00 PM   #9
Given the choice, I'd put it in a room or hallway, and hide it behind a hinged mirror or painting (like they do at resorts).
Old 03-30-2011, 01:05 PM   #10
I'm in southern Arizona so I'm guessing exterior mounted isn't too big of a deal. Less than 8" of precipitation per year and only a handful of frosts...
Old 03-30-2011, 10:18 PM   #11
It's very common to have them mounted externally here in Colorado and we get a lot more cold weather and precipitation than AZ.
InmatesRunWild is offline   Reply With Quote
Tags
sub-panel, subpanel
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
