Sub Panel Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 09:30 PM   #1
sub panel installation
i'm installing a 100amp 24 circuit sub panel in my detached garage, i'll use maybe 6-8 circuits. the walls are 2x8 construction and i wanted to recess the panel into the wall, however, where i want to mount the panel,about a third of the knockouts will be inaccessible(about 15) there are 25 knockouts available. as per the ontario electrical code. thanks.
chevy1 is offline   Reply With Quote
Old 10-29-2011, 09:43 PM   #2
Sparky
Rewards Points: 510
when you're finished... all of the KO's will be inaccessible. go for it.
Techy is offline   Reply With Quote
Old 10-29-2011, 10:21 PM   #3
Sfeyelectric's Avatar
Not gonna feed a lot with 100watts, do you 100amps?
Sfeyelectric is offline   Reply With Quote
Old 10-30-2011, 02:20 PM   #4
Yes I meant 100amps
Old 10-30-2011, 05:46 PM   #5
Originally Posted by chevy1 View Post
Yes I meant 100amps
Sorry was just messing with you, call your code enforcement as they will know your local code. If you are flush mounting it they will all be covered in the end anyway!
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 02:05 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 12:20 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
