Sub Panel Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2010, 03:18 AM   #1
Sub panel help
Installing a 200amp all in one box outside , not much will be on this one, just a few circuits - 30 ft away I need a 125 amp sub panel 22 breakers 15 & 20 amp & 6 240v lines that are ALU old gray type wire & will have 30,40,amp breakers. Will power a 2 ton & a 3 ton air unit.
What wire size should I run 1/0 or #2 wire to the sub ??
2 hot -1 neutral, & what size for the ground ?
please explain about keeping the neutrals and ground buss separated, only in the sub panel?
Permits are in hand.
Thanks for the knowledge.
shortsell is offline   Reply With Quote
Old 04-08-2010, 06:18 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
First step is to get a permit. Requirements may vary a little but your Safety and Liability are on the line.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-08-2010, 08:52 AM   #3
Licensed electrician
Rewards Points: 1,010
Have you done a load calculation to see what size feeder you need to the subpanel? The 125 amps is just the max that can feed that panel.
Also refer to this sticky post.
Stubbies Diagrams and other stuff
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
