Old 09-30-2012, 03:33 PM   #1
sub panel help
Hi,
I have a 220 line from a range that was used prior to us installing a gas range. It's a 50amp line that is now unused. I would like to use that line to feed a sub panel that would allow me to add two circuits for a swimming pool plus a circuit or two for a hobby area in my basement.
The problem... the range line has two hot wires and one neutral, no ground. I can't easily pull another wire because the main panel is in a closet in the finished area of the basement with no easy way to pull new wire. So, how can I get a fourth wire over to where I want to put my new panel?
The previous owner converted the electric water heater from electric to gas, so I also have a 220, 30amp feed left over from that... Can I convert the hot lines from that into grounds and extend them over to the new sub panel?
Any other ideas?
Thanks.
Dougget is offline   Reply With Quote
Old 09-30-2012, 03:39 PM   #2
A "Handy Husband"
rjniles's Avatar
sub panel help
You have SE cable - 2 insulated hots and a bare ground. You cannot use to feed a panel. You need 2 hots a neutral and a ground - 4 wire feed.
And a big no to you plans to combine 2 old circuits. You need a new cable back to the panel.
Coastal South Carolina
Old 09-30-2012, 04:22 PM   #3
Master Electrician
sub panel help
I would respectfully add, an insulated neutral.
brric is offline   Reply With Quote
Old 09-30-2012, 08:29 PM   #4
sub panel help
Yeah, I kinda knew that wasn't a good way to go.
How about making the sub panel a 110 only panel. Use one of the existing hots as a hot, convert the other to neutral, and use the existing bare neutral as a ground?
I'll replace the duplex 50 amp breaker with a single breaker in the main box.
How would that work?
Doug
Old 09-30-2012, 08:33 PM   #5
Missouri Bound's Avatar
sub panel help
Doug
That can be done. Just be midful of the loads because the neutral will take all the load in a 120 panel, rather than the reduced load a 240 panel has on the neutral.
Do you want it your way or the right way?
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
