Sub Panel Grounding Question. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-23-2008, 04:44 PM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Do you guys want my long version or short version.......
Old 02-23-2008, 04:54 PM   #32
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by CowboyAndy View Post
When there is a lightning strike, WHY will it go to earth instead of through the service neutral?
This a lot like the question; what does an 800 pound gorilla eat for breakfast?
answer; anything he wants
Something as powerful as lightning with its billion volts goes anywhere it wants. All we really do is try to direct it away from things we do not want blown up.
Sometimes it works; sometimes it doesn't.
that is why I am willing to help the neighbor pay for a lightning arrestor system. I figure the air terminals on his house will be more attractive than my little ol house so it will flow to his house and avoid mine. I figure if the air terminals are on my house, it is like standing up at the biker bar and yelling HD sucks. Nothing worse than intentionally drawing attention to yourself.
Old 02-23-2008, 05:50 PM   #33
Electrician
Your theory is off, Lightning systems do not attract lighting... neither do ground rods...
chris75 is offline   Reply With Quote
Old 02-23-2008, 06:12 PM   #34
Long version.
RobertS is offline   Reply With Quote
Old 02-23-2008, 06:19 PM   #35
electrical contractor
Rewards Points: 150
Guess I never really thought about it, one of those things, teacher says do it this way and we do it. Thanks for opening my eyes, sorry for the question phrased that way Petey. Guess I better heed my signature line and get tough because I sure have been dense on grounding.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-23-2008, 06:26 PM   #36
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Twister, let me be the first to say thank you for that post. That shows real character.
Old 02-23-2008, 06:30 PM   #37
Rewards Points: 150
Stealing somebody elses signature line
"if your gonna be stupid you better be tough"
Jimmy
Old 02-23-2008, 06:49 PM   #38
Rewards Points: 2,350
It isn't hard to get grounding confused. It is the most mis-applied section of the Code. Seems hardly anyone understands it, and I think this is mostly due to the language used. If all our green or bare circuit wires were called "bond conductors" instead of "grounding conductors", and define them properly in the code, we'd be on the right track to eliminating this confusion.
Become an expert on grounding and bonding, and other electricians will be in utter awe of your knowledge.
InPhase277
Old 02-23-2008, 06:58 PM   #39
UAW SKILLED TRADES
Stubbie's Avatar
Robert
This thread has two directions one being is earth a fault path for opening an overcurrent device and your original question about when ground rods are required at sub-panels any why 3 wire feeders vs 4 wire feeders vs a single 120 volt branch circuit making a difference whether we use ground rods or not.
Are you wanting the reason for ground rods at detached structures and when the NEC requires them or are you wanting to know about earth and grounding, grounded and ground and how it pertains to the electrical system?
Old 02-23-2008, 07:18 PM   #40
Why use a ground rod on a 4 wire isolated ground detatched sub panel. We haven't been using them for years on manufactured homes.
Old 02-23-2008, 07:30 PM   #41
Electrician
Because of 250.32(A)
Old 02-23-2008, 07:38 PM   #42
Never failed an inspection.
Old 02-23-2008, 07:39 PM   #43
Electrician
Thats too bad... show them 250.32(A)
New York does not have continuing education classes?
Old 02-23-2008, 07:53 PM   #44
UAW SKILLED TRADES
Stubbie's Avatar
Are your manufactured homes on permanent foundations? The equipment ground in the four wire feeder has nothing to do with whether or not you have a ground rod they serve different purposes. Your mentioning of a four wire feeder tells me that the service equipment is not attached to the manufactured home. Second a manufactured home is a different duck depending on circumstances than.... say a detached garage.
Is your question centered around if I have a ground with the feeder why would I need a ground rod?
Old 02-23-2008, 08:06 PM   #45
This does not surprise me in the least.
Not at all.
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 09:01 PM
Main panel design question amakarevic Electrical 13 06-04-2007 04:35 AM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
Grounding Sub Panel jmccue Electrical 2 02-07-2007 11:24 PM
