#1 |
sub panel grounding
Hi guys
Quick question. I have seen a sub panel that is connected to the panel with metal conduit also have a ground wire run and bonded to the sub-panel. everything else is bonded at the main neutral and ground and panel. It is my understanding that you need not to run a ground wire if the sub panel is connected to the main panel by metal conduit. The ground wire he ran just came out of the conduit and was screwed directly to sub panel cabinet. Is this ok thanks Jrff |
#2 |
canfixmost
sub panel grounding
Most sub-panels need to have an isolated neutral bus bar and a grounding
bar. Check local codes. The reason why is to be certain no current will flow when a ground wire is disconnected for any reason. You should install a ground bar attatched directly to the panel box and seperate the grounds from the neutrals. You do not really need any additional grounding if connectors are not insulated and are tight. An extra ground wire will not hurt anything, its just not required. Yes thats OK. Last edited by RenoDon; 05-04-2009 at 07:24 PM. |
#3 | |
sub panel groundingQuote:
Generally we install a ground bus to accept the branch circuit grounds, but there is nothing saying that you can't just run the ground right to the can. |
| Display Modes | |
| new Main Panel Grounding | lrr81765 | Electrical | 8 | 10-09-2008 12:16 PM |
| Replacement Meter Panel | leonard_voet | Electrical | 19 | 04-09-2008 11:27 AM |
| Detached Garage Sub Panel Grounding Q | integlikewhoa | Electrical | 13 | 01-01-2008 07:22 AM |
| advice on installing equipment grounding bar in main panel | pacifier1er | Electrical | 5 | 05-29-2007 06:55 PM |
| Grounding Sub Panel | jmccue | Electrical | 2 | 02-08-2007 12:24 AM |
