Sub-Panel Grounding? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 09:24 PM   #1
I had an electrician install a 50-amp sub-panel in my basement a few years ago. He used an existing 3-wire (black, red, white, no ground) 6 gauge cable. It is fed from a 50 amp breaker in the main panel in the attached garage. The ground bus on the sub-panel is connected to the main copper water line by #4 green wire.
Is this proper? I have read on other posts that a sub-panel should be connected to the main panel with 4 wires.
Thanks.
Bicoronal is offline   Reply With Quote
Old 05-20-2011, 09:38 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
no it is not proper and never was.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-20-2011, 10:21 PM   #3
Rewards Points: 1,016
To correct this can the OP just run a ground wire from the main to the sub panel - and leave the existing cable as is?
____________
Vince
Old 05-20-2011, 11:07 PM   #4
Scared Electrician
the short answer is NO
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
sub panel grounding bcarl Electrical 4 01-23-2011 10:37 PM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
Electrical Sub Panel Grounding KellyElaine Electrical 17 01-17-2011 06:46 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
