Sub Panel Grounding - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 10:22 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Proximity to a door is not important. Just make sure you have a 30" side space (and the 30" space for this panel can overlap the 30" space for the main panel up to 100%) with 3 feet out from the wall clear. Then under and above the panel, nothing from the floor to the ceiling.
Height: it's either 6' 6" or 6' 7" (can't remember offhand. I think they changed it a couple code cycles ago and never remember the exact number) to the top breaker handle in the up position (if it flips up and down) max height. I generally set the top of the panels at 6'. (which is obviously lower than the max.
Old 04-26-2011, 06:05 AM   #17
Bluwolf's Avatar
Rewards Points: 87
I'm off to Parrottsville, Tennessee that is! Thanks Again, nap!
Bluwolf is offline   Reply With Quote
Old 04-26-2011, 07:19 AM   #18
I=E/R
a7ecorsair's Avatar
that would probably be worse than Ely Michigan.
a7ecorsair is offline   Reply With Quote
Old 04-26-2011, 12:37 PM   #19
nap
You talking to me?
nap's Avatar
Originally Posted by a7ecorsair View Post
no offense intended. It's just that I enjoy our weather here. While I do like cold weather, there are limits to what these aging bones can withstand anymore and where I live seems to fit me just right.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
sub panel grounding bcarl Electrical 4 01-23-2011 10:37 PM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
Electrical Sub Panel Grounding KellyElaine Electrical 17 01-17-2011 06:46 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
