Sub Panel Ground Bars - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 09:22 PM   #1
Rewards Points: 93
I just converted a 125 amp GE panel from a main panel to a sub-panel. It is now connected (thru PVC conduit) to a 60 amp breaker in the main Square D panel in a detached building.
I separated the neutrals and grounds and only the grounds are bonded to the can.
It was much easier to add 3 ground bars in different areas of the panel than to pig-tail onto the ground leads and then all land on 1 ground bar.
Does code allow multiple ground bars?
George6488 is offline   Reply With Quote
Old 01-05-2013, 09:27 PM   #2
Electrical Contractor
kbsparky's Avatar
Yup...
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
George6488 (01-05-2013), NJMarine (01-06-2013)
sub panel ground katahdin Electrical 4 04-21-2011 11:13 AM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 10:17 AM
