Sub Panel Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2009, 03:58 AM   #1
Sub Panel Ground
I have a small sub panel in a detached garage. It is grounded to the main panel which feeds it, but not to it's own ground rods.
How far from the sub panel can the ground rods be? I either have to drill through a slab to drive the rods just outside the wall the panel is on, or run the ground wire over a door opening to where there is exposed earth (about a 12' total run).
Thanks...
Gary
garyoutwest is offline   Reply With Quote
Old 05-03-2009, 08:05 AM   #2
Sub panel needs its' own ground, but the neutral buss must be separate from the ground buss on the sub panel. Neutral comes from the main panel. 12' is not an especially long distance.
Old 05-03-2009, 01:01 PM   #3
Rewards Points: 82
Actually you may need two ground rods at the unattached structure. Don't go over any doors or have a long run of grounding electrode wire. The wire is supposed to be run in as straight a line as possible. Remember. The ground rods and wire are for lightning protection. I would want that fault to have a very short path to earth.
J. V. is online now   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 04:15 PM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 11:17 AM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
