Sub Panel Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 09:50 AM   #1
sub panel ground
my recent post about a sub panel in attached garage was answered and i am wiring as instructed but dont understand the concept of why i need a seperate ground and neutral wires and ground and neutral bars in the sub if they are both wired to the same ground bar in main panel. help me understand this. thanks
waynebo is offline   Reply With Quote
Old 06-03-2011, 12:08 PM   #2
Licensed Pro
The neutral is a current carrying conductor. Tie it to the ground at both ends and the ground also becomes current carrying... not a good (or safe) thing.
Old 06-03-2011, 12:56 PM   #3
I=E/R
a7ecorsair's Avatar
I will expand the other explanation.
1) The neutral carries current back to the transformer so the neutral in your sub panel is connected to the neutral in the main panel.
2) The ground is not supposed to have current flowing in it except in a fault condition.
If the ground wire and the neutral wire were connected in the sub panel as they are in the main panel then the neutral and ground would each be carrying a portion of the return neutral current. There is a lot more theory to it but in a nut shell this is the reason.
a7ecorsair is offline   Reply With Quote
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Service panel ground downunder Electrical 13 05-13-2011 04:46 PM
Sub Panel Ground and Neutral COLDIRON Electrical 6 01-08-2011 10:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
