Sub Panel For Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 06:51 PM   #1
Sub panel for generator
I would like to install a sub panel off of my main its 200 amp sq d homeline . I want the grounds and neutrals in the sub to so I won't have to worry with unbonding gen . My gen can do 50 amps but the sub would have a good many breakers I'm all elec. what I won't to do is have a inlet on sub from main and be able to unplug that and then plug my gen in . The only plug I see big enough to handle grid power would be a pin and sleeve plug maybe a 125 amp or 150 amp I could manage the load when on gen power . Is there another plug you would know of . I have a bobcat 225 welder I do not want to unbond it but I don't want to run it though the main with a interlock when it's bonded
Kpack is offline   Reply With Quote
Old 11-10-2012, 06:52 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You cannot do what you want. Its time you do more research on the proper way to connect a generator.
The Following User Says Thank You to k_buz For This Useful Post:
Kpack (11-10-2012)
Old 11-10-2012, 07:14 PM   #3
I have looked at a lot of ways I just want to be totally off the grid where I hook the gen.
Old 11-10-2012, 08:34 PM   #4
Don't worry about it being bonded or not. Just run it to an inlet and install an interlock on your panel, and be done with it. You can find one cheap for a Square D panel.
Regination is offline   Reply With Quote
The Following User Says Thank You to Regination For This Useful Post:
Kpack (11-10-2012)
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
