Sub Panel Buzzing/shorting Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2013, 11:23 PM   #1
Rewards Points: 37
Sub panel Buzzing/shorting noise
I have this outdoor sub panel that has a GFCI outlet, an HPS dusk-dawn light and two outdoor lights on a switch connected to it. I was grilling some food the other night and turned on the outdoor lights and I heard a buzzing/melting/metal fusing sound in the panel so I turned it off right away. Turned off the breaker, now when I turn the breaker back on, even with outdoor light switch turned off, i hear the same noise. this is a new thing, it has worked fine for a couple of years. whats going on? Below are photos of the box when I took the cover off, and the outdoor light switch.
RodBarney is offline   Reply With Quote
Old 06-06-2013, 01:56 AM   #2
Rewards Points: 1,192
Looks like water caused rust and corrosion. Get a new box and breakers and land the grounds on a seperate ground bar and the neutrals also on their isolated neutral bar.Might need a ground rod,also.
bobelectric is offline   Reply With Quote
Old 06-06-2013, 01:32 PM   #3
Rewards Points: 506
That is one messed-up-looking installation!
1st, where are the bare, and Green insulated ground wires terminated, if at all? I hope that one of them is not going to that breaker. (Is that supposed to be a GFCI Breaker?)
Where does that Red wire terminate?
The neutral termination lugs need to be reworked; the screws are all rusty. I would back the screws out, re-strip the White wires, and re-terminate them, tight.
Installation is the Reverse of Removal.
Old 06-06-2013, 03:21 PM   #4
Rewards Points: 324
the red is terminated to the right of the tandem brkr.it is a hot in.
oleguy74 is offline   Reply With Quote
Old 06-06-2013, 04:50 PM   #5
Licensed Pro
Water damage. Replace the panel.
Old 06-06-2013, 10:30 PM   #6
Rewards Points: 446
Make sure you replace it with one rated for outdoor use.
old_squid is offline   Reply With Quote
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
