Sub Panel Breaker Size - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 07:53 PM   #1
What would be the recommended breaker feeder size be for a sub panel if I move 2 double pole 15A breakers that feed the kitchen counter plugs into it? Please note, I am in Canada and code here used to be such that a 15A double pole breaker feeds up to 2 outlets that are split wired for the kitchen. Out kitchen has 4 plugs thus there are 2 15A DP breakers. I need some space in the main panel and these would be the best choice to move.
rhombixt is offline   Reply With Quote
Old 01-09-2012, 08:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
Figure the size of the feed based on the load you expect.
You already know you need the 2 15 amp breakers, so what else are you going to add.
Cost wise, there's not much difference between a 30 amp feed and a 60 amp feed.
jbfan is online now   Reply With Quote
Old 01-10-2012, 04:33 PM   #3
The new panel only has room for 4 breakers and that all. The new breakers need to be double Pole GFI breakers so that will be all the load in the sub.
Old 01-10-2012, 04:40 PM   #4
jbfan's Avatar
Rewards Points: 400
If that is all the load you will ever put in that panel, the I would not do less than 30 amps
The Following User Says Thank You to jbfan For This Useful Post:
rhombixt (01-10-2012)
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
What size breaker for 4100 watt wall oven? romexican Electrical 3 09-15-2009 09:34 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
I can "double" the wires to each breaker in my breaker panel right? Piedmont Electrical 40 10-01-2008 11:18 AM
